Backfiring Carb
Discussion in 'The Garage' started by wfo163, Apr 27, 2004.
  1. wfo163
    wfo163 1/2 ton status
    Jan 11, 2003
    100
    Charlotte, NC
    this thing is annoying me. I have an edelbrock 600cfm part# 1406 carb on top of a performer intake running into a stock 454, stock except for the comp 4x4 cam inside it anyway. So when ever I try to drive this thing with the motor cold I get multiple backfires through the carb. It clears up when the engine is about 200 degrees. Anyone else had these problems? Is maybe the choke causing this to happen? I know I know, get fuel injection!
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    It might be an exhaust leak close to the exhaust manifold, and when it warms up the leak seals itself. Make sure the EGR valve is not stuck open, if you have one.
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    It sounds like you are running lean. Might just need to adjust the choke
    OR
    Is the carb set up for a big block? Most 600CFM carbs are jetted for small blocks.
    You may need to get smaller meetering rods or diferent jets,to meet the fuel needs of a BBC. Espically one with a cam.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ignition related
    a carb will rarely cause a spark in the intake
