backfiring out of carb, then shuting off when put in gear
Discussion in 'The Garage' started by moose73, Apr 30, 2003.
  1. moose73
    moose73 Registered Member
    Apr 11, 2003
    22
    chatt,tennessee
    truck was running great then started spitnsput backfiring out of the carb. messed with timing replaced a plugwire and runs good in park then put in gear in will die? any suggestions
  2. dyeager535
    26,980
    WAG, vacuum leak along with incorrect timing. Higher engine speed covers up the bad vacuum leak, under load, engine RPM drops too low, and stalls from the vacuum leak.
    Also could be mech. advance mechanism in the distributor. Along with 80 million other things unfortunately.:(
    If idle speed is correct, then I'd doubt plugs/wires, as it would lope a bit at idle. Can always disconnect one plug wire at a time while its running to make sure the cylinder is firing, cheaper than buying new plugs and wires all the time.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    Re: backfiring out of carb, then shutting off when put in gear
    start it up with the air cleaner off then cup your hands over the top of the carb if the idle goes up you have a vacuum leak if it kills it you have another problem /forums/images/graemlins/eek.gif
  4. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    When did it start? I would say vacume advance on the distributer. Check the line coming off the carb to it first to make sure it is getting a tight seal. If it is then look at replacing the distributer. Don't overlook Timing. Get a light and put it on there. An ear is good, but nothing is better than a light.
  5. dyeager535
    26,980
    You can rebuild these things cheaply and easily, not sure why you'd throw a distributor away. /forums/images/graemlins/confused.gif
  6. bee32
    Aug 6, 2001
    401
    Virginia Beach Va.
    True!
  7. moose73
    Apr 11, 2003
    22
    chatt,tennessee
    i replace the pickup coil and mechancal advance it tested bad at low rpms at the parts store vacuum advance was okay havent put the light to it yet or checked the plug/wire. someone said a float could be hung up but in idles and revs great in park?
  8. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    plugged fuel filter making it super lean, or a bad valve, stuck valve. thats my guess
