Backfiring Problem
Discussion in 'The Garage' started by BurbLover, Jul 22, 2004.
  1. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    I've got an 85 stock K30 with a 350/SM465 that has a bit of a backfiring problem. Typically, this occurs when I'm trying to get speed up quickly. My plan is to give it a tune-up when $$ allows. I plan to change plugs/wires/cap/rotor/fuel filter/air filter.
    I've alos tried running fuel additive to try & clean out system but it still does it.
    Anybody know what the source of this problem might be?
    Any comments on my tune-up? Anything else you'd change as well?
    Thanks.
  2. mrk5
    Apr 20, 2004
    12,346
    1,049
    Northern Colorado
    Backfire from the exhaust or the carburetor?
  3. clubba68
    clubba68 1/2 ton status
    Dec 6, 2002
    1,511
    Eugene-Portland, Oregon
    Having a similar problem. Have you checked the timing?
  4. wkasak
    wkasak Registered Member Premium Member
    Jun 28, 2002
    59
    Elkridge, Maryland
    Could be many reasons...my recent backfire issue was due to burned through spark plug wire/s. Damn headers... /forums/images/graemlins/grin.gif
    Do a good tune up including wires, plugs, distributer cap, timing check. Usually clears it up. If not you have removed the basic problems.
  5. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    exhaust
    I didn't think about the timing. I'll check that when I do th etune-up. My first guess was a bad/missing spark somewhere. Maybe even a couple of cylinders.
    Thanks for the responces. You guys made me /forums/images/graemlins/smile.gif
  6. mrk5
    Apr 20, 2004
    12,346
    1,049
    Northern Colorado
    Could also be the float level too high, or the idle mixture could be a little rich.
    I would check the above after the tune-up, if the problem still exists.
  7. BurbLover
    Jul 31, 2001
    3,060
    SW Missouri
    I am carb illiterate!! After I try a tune-up. I may have the carb rebuilt if the problem persists. I'll just solicit for some carb help in the Co Springs area.
  8. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Check your timing. Sometimes the timing marks are off a bit so you may have to make slight adjustments and give it a go.
  9. backcountry
    May 27, 2004
    916
    Walt,
    Nice rig man! /forums/images/graemlins/waytogo.gif
  10. wkasak
    Jun 28, 2002
    59
    Elkridge, Maryland
    Walt,
    Thank You...That's my baby...Lot's of blood, sweat, and tears into it. I joke with people about being buried in it when I die... /forums/images/graemlins/waytogo.gif
  11. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    I had the same problem with my old 305. it turned out that my distrubitor shaft was broke.
