Backfiring through the Carb on acceleration
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dlferry, Apr 9, 2006.
  1. dlferry
    dlferry Registered Member
    May 8, 2004
    6
    I have a newly rebuilt Chevy 355 Gen 1 block. It runs and idles great however it from time to time backfire through the carburetor on acceleration. I currently have the timing advanced 24 degrees. I am thinking it is carburetor related but not sure. Am I on right track?
  2. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Wouldn't be a Carb problem I don't think. Sounds like an intake valve issue. I'd say burnt intake valve, but you said it was just rebuilt?
    Perhaps the valve is sticking or not closing all the way?
  3. littlejimmythatcould
    littlejimmythatcould 1/2 ton status
    Feb 6, 2006
    797
    Clovis, NM
    Once in a great while mine would do that when it's cold. But I put a new carb on it and it fixed it. i don't know how but it did. Plus the carb I was running was probably eight years old and had vaccuum leaks all over it. Swapped a new one on and now everything (especially my brakes) work better. Now I'm just having trouble with detonation.... trying different metering rods. Maybe your timing is too high. Mine only runs at I believe 12 to 14 degrees advanced, but I have points ignition.
  4. farshot1
    farshot1 Surrender the Booty
    Mar 17, 2006
    37
    South Carolina
    Possible that the vacuum advance is bad.
  5. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    Which brand and model number is your carb? Does it do the carb backfire thing on light acceleration, but not when you really punch it?
  6. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    Mabey running too rich, or getting to much gas too quickly. My holley was like this when I put it on my 4.3lv6 (390cfm holley), i had to put A smaller shooter and a different pump cam in to get rid of it.
  7. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    24* sounds like Alot of initial advance. Are your valves adjusted properly?
  8. mrk5
    Apr 20, 2004
    12,329
    1,037
    Northern Colorado
    Here's something I found:
    24* is a lot. I have mine advanced 15* and I live at 5000ft.
    Where is your vacuum advance hooked up?
    HEI dist? From what year?
    I'm asking because I'm wondering if you have your initial timing set really high and it is compounded by vacuum advance making it even higher.
  9. johnathan
    johnathan 1/2 ton status
    Sep 26, 2005
    376
    Ocean Springs,MS
    Mine used to do that from a lean condition Chek for manifold leaks and could just be the carb.Does it surge any at light acceleration?What carb?
