Backfiring thru TBI
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Trigger, May 13, 2003.
  1. Trigger
    Trigger Registered Member
    May 5, 2003
    48
    Independence, MO
    What would cause this? I haven't done anything to the timing at all. I replaced the rotor,cap, and plugs 2 weeks ago. It's having a hard time starting now also.
  2. Trigger
    May 5, 2003
    48
    Independence, MO
    Where is the idle fuse located? I didn't see it in the fuse box under the dash.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check for a intake gasket leak
  4. Grim-Reaper
    7,385
    Atlanta
    Has it been doing this imeadeatly since you changed the cap? You may have got the firing order out when you changed it.
  5. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    sounds like you may have gotten the wires crossed. clock wise 18436572 is the correct order just for reference.
