Backhoe/Payloader ponderance...
Discussion in 'The Lounge' started by newyorkin, Dec 15, 2004.
  1. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I have to dig a drywell, trenches along the foundation, a large hole next to the foundation, dig out an old drywell, and move 20 yards of topsoil. I also have to dig out 2 stumps (1 right above a water main), and if I get time with the machine, I'd want to dig yet another drywell way in the back yard.
    I was going to rent an Allmand at the suggestion of a rental place guy. Another rental place just suggested I use a WB140, which is $125 rate more for the day, but seems like overkill.
    The Allmand can dig 9ft, and has a lift capacity of around 1000lbs. I think I'll need more lift cap for the concrete drywell rings, but I really don't know. 9ft should be deep enough, the one I'm digging out was 8ft, but we installed it wrong originally, I think it was draining ok. The Allmand can move the soil probably just as good as anything. I dunno how it will do with stumps, with the lower lift cap, I'd bet it's a lot less powerful.
    The WB140 can dig over 12 ft, and can lift around 2900lbs. The drywell's should be a cakewalk for it. Moving the 20 yards should also be pretty easy for it. The stumps shouldn't be too hard either.
    Here's the Almand:
    Here's the WB140:
    So basically, it looks like the allmand can do the work, the WB140 can smoke the work.
    I can get an allmand for around $320 for a day, the WB140 works out to a little under $600 for a day.
    Ah nevermind, I think I just figured it out, I'm going with the allmand. But man that WB140 is HOT!!
    I hope it's joystick controlled...I hated the levers when I drove a payloader years ago.
    Anyone have any constructive input (no pun intended)?
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i used to work for komatsu equipment, and you're right the WBs are nice. never even seen an allmand in my life... now i work for john deere heavy equipment and i personally like the deere backhoes more. ours are more powerful. the komatsu ones are just more comfy inside.
  3. Resurrection_Joe
    Resurrection_Joe 1 ton status
    Jan 9, 2002
    17,372
    Gettysburg, SD
    Make sure you do soemthing rediculous and hilarious with it while you have it
  4. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    like pull up an 18 inch sewer line??:eek1:
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Well get the Almand for 320 a day, then if you need the extra depth or capability, get the WB for alot shorter time at 600.
  6. newyorkin
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    As much as I'd love to, that's totally out. The biggest expense is transport. Niether can be street driven, and the place with the WB140 wants $140 each way for delivery (WB140...$140...Coincidence?). Ironically, they're only a mile from me, the place that wants $80 each way for the Allmand is 15 miles from me...
    I dunno what numbers I was thinking before, but it'll actually work out to almost $700 for the heavier machine. I'm chewing my knuckles at dropping almost $400 on this project, $700 will have me in panic mode. I picked the wrong season for this stuff...
    One place had the allmand for $160 a day, but I had to transport it, and they were 15 miles away, too. I don't have a vehicle or trailer that can tow these machines (wb140 is delivery only anyway, it's 16,000lbs). $160 would've so totally rocked dude...!
    Muddysub, the John Deere equipment is pretty nice. :thumbsup:
