backlash ....gears...How do I check with the
Discussion in 'The Garage' started by jakeslim, Aug 17, 2003.
  1. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    ok, how do I check the back lash. I have the carrier back in the 14ff rear end, I put the pinion back in to adjust the backlash, but how do I check with the dial thing and the magnetic base? Where do I put it, what does it measure and how do I read it?
    help...
  2. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Set it up so the indicator is in-line to the ring gear (or as close as you can get it) rideing on the outer edge of the teeth, paralle to the ring rear's direction of rotation.
    Hold the pinion in position, and rock the ring gear.
    Specs call for .003" - .010" (.005-.007 is best)
    While we're here,
    Pinion AND Case bearing preload, new bearings = 30 - 55 in/lbs
    Pinion AND Case bearing preload, used bearings = 25 - 45 in/lbs
    Pinion only, new bearings = 15 - 30 in/lbs
    Pinion only, used bearings = 10 - 20 in/lbs
    I looked all that up, for another post - putting it to good use.
  3. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    236
    Oak Harbor, WA
    here is how I set mine
  4. jakeslim
    Sep 18, 2002
    2,686
    Napa, CA
    excellent, thanks!
