backpressure
Discussion in 'The Garage' started by tecton, Apr 5, 2004.
  1. tecton
    tecton 1/2 ton status
    Dec 1, 2002
    1,553
    WV
    what does it mean when a truck runs BETTER with back pressure....that is, an open muffler would decrease performance
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    It probably means that your fuel mixture is incorrect, typically too lean for the free flowing exhaust.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    It's usually a bandaid fix for a broken leg related to fuel metering and cylinder filling. Search on Google for it to be explained.
  4. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Then why does everybody say you NEED backpressure, even if they have no clue about your fuel mixture.
  5. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Performance in an exhaust system is all about flow. If a pipe is too large the velocity is too low. If a pipe is too small the velocity is too high. There is a balance at which the flow is greatest. Dual 3" habitrail exhaust works excellent on a blown bigblock but it doesn't treat your mom's 4.3L V6 in her Astro so well.
    Backpressure is the measure of a lack of flow. The more restriction the more power lost to pumping the exhaust out. Any more than 1.5psi at the collector is too much.
    Maybe you should ask those people why they think you need backpressure? They'll probably tell you that a little birdy told them. [​IMG]
  6. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    my blazer currently has open headers waiting for an exhaust and it runs like a turd. The motor has 10k miles on it. I was told that when you hit the exhaust stroke the valve timing overlaps so that both the exhaust and intake valve are open at the same time for a small period. What this does is use the velocity of the exiting exhaust gasses to pull more fuel/air into the cylinder. But with open exhaust you can pull some of the new unburnt air/fuel out the exhaust port causing a lean condition in the cylinder, poor fuel economy, and backfires from unburnt fuel in the exhaust pipes...and judging from the flames that exit my headers I'd be inclined to believe it. But keep in mind this is something I was told by a mechanic and I personally have no scientific data to back it up.
  7. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    Yeap, there be overlaps. If you were to watch the carb of a lopey-cammed vehicle with a timing light you'd see that metered air is actually going back through the carb a second time.
    Open headers don't work at low rpm for a number of reasons. I'd explain it but Google does so much better than me.
  8. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    It all has to do with the torque peak of the engine. If you want to rev your motor past 5000 rpm open headers or OVER 3" is for you. You have to not only change your metering but also your ignition timing. Even just doing a muffler change will change your peaks. IMHO you need no more than 2.5" exhaust on a natrually asperated mildly built truck motor. You can tune it right get your mixture perfect and have your power right where you need it, low in the RPM band. /forums/images/graemlins/thumb.gif
