Backspacing between SRW and DRW axles
Discussion in 'The Garage' started by thatK30guy, Aug 19, 2003.
  1. thatK30guy
    Jan 12, 2001
    32,076
    55
    How much backspacing is necessary to clear the D60's in both SRW and DRW without doing any grinding on the calipers or mounts?
    I'm asking so I can check into using aluminum Weld Racing wheels of 15" onto a DRW front and want to set it back far enough to where grinding won't be nessary. This way I can tuck the tire back into the fender slightly but still have a wide stance.
    Does this make sense? /forums/images/graemlins/tongue.gif
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Hmmm, let's see here... The DRW axle is 4" wider on each side, and I would think that you could run 2" of BS on an aluminum wheel on a SRW 60, so I'd guess that you'd be good to go with 6" of BS on a 15" wheel on a CRW axle. It's gonna be wiiiide and will probably rub like crazy when you turn the wheels. /forums/images/graemlins/thinking.gif</font>
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    So with a 2" on a SRW, it will clear the calipers without grinding? Sounds like a plan in the works soon.
    I've already thought about the stance situation. Siknce I don't deal with rocks in KS, don't have to worry about that. It's all mud here. That wide stance should give some more stability.
    I've got planned to use a D60 and 70 dually axles and 15" Weld Racking SR-series wheels on 44" tires.
    What I'm tryhing to decide to install them udner is something ike the White Knight...tubed chassis, etc. etc. /forums/images/graemlins/thinking.gif
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'm just guessing on the 2" BS thing, I know that with steel wheels you can go 2.5" with no grinding, and it doesn't seem like an aluminum wheel would be more than 1/2" thicker than steel, so it seems like a good number to start with. I don't think I've ever even seen an aluminum 15" 8 lug wheel though, so I'm not sure if anyone will know this for sure. </font>
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Go to the Weld Racing Wheel site and check out their SR-series wheels. /forums/images/graemlins/wink.gif /forums/images/graemlins/thumb.gif
