Backspacing with a 42?
Discussion in 'The Garage' started by trollporter, Jul 6, 2004.
  1. trollporter
    trollporter 1/2 ton status
    Feb 29, 2004
    518
    Lady's Island, SC
    What is the most ideal backspacing to run with 42's? The truck has 6" sup. and 1" body. Will the front axle need to be pushed foward?
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
    PICS ARE WELCOME!!!
  2. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    I hope your ready to trim! /forums/images/graemlins/laugh.gif
    I run 4" lift with 42" TSLs on 15 x 8 rims and 4.25" backspace and the axle moved forward about 4.5" or so. It cleared fine with the axle only 2" forward, but it was close when heavily articulated and turned. And if things are turned-n-twisted right, they "caress" my shocks and steering box, though no problems have resulted, just some marks and shiny spots.
    Back space required also has a lot to do with tread width, tire pressure, and wheel width.
  3. SCOOBYDANNN
    SCOOBYDANNN 1/2 ton status
    Sep 4, 2001
    2,129
    21
    El Paso, TEXAS
    6" axle not moved at all but the springs are kinda stiff. I had to beat the firewall and it still hits at full stuff. i can still turn everythning and haven't had any problems except the firewall.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I only run 38.5s on 6" of lift with the axle moved forward 1.5" and I cannot achieve full stuff because the tires are against the floorboards.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Rim width will play an important role in what backspacing is ideal. With an 8" rim, 3.75-4.25 is ideal. With a 10" rim you'll want to stay closer to 4.25 - 4.5. You'll need to push the axle forward if your truck flexes very well at all.
