Backspacing
Discussion in 'The Garage' started by Catman, Apr 20, 2004.
  1. Catman
    Catman Registered Member
    Feb 4, 2003
    53
    Yucca Valley, Calif.
    Thanks for the help on rim width. I'm about to order the new wheels and have a question on backspacing. Did the search but alot of apps need grinding. I run 35x12.50 BFG mt's with 4" of lift. What bs will work with NO grinding. Oh yeh, it's a 10 bolt diff. /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/thumb.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    If it's a 1/2 ton 10 bolt (6 lug), you won't have to grind at all. You can run 15" aluminum or steel rims, and I recommend anything from 3-4" of backspacing...3 5/8" would be ideal.
  3. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    According to your profile, you are still running front and rear 6-lug 10 bolts axles. Therefore, you will not need to grind anything. Most rims come in the 3-4" range, so take your pick. /forums/images/graemlins/waytogo.gif
  4. heavy4x4
    Aug 28, 2002
    3,270
    /forums/images/graemlins/tongue.gif
  5. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    I see you are quicker on the draw!! /forums/images/graemlins/doah.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/peace.gif
  6. Catman
    Feb 4, 2003
    53
    Thanks folks. Summit Racing is about to get an order. This time it's steel. Screw the alloys!!! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  7. firefighter184
    firefighter184 1/2 ton status
    Apr 5, 2003
    2,763
    The Barrio
    I'm runnin 33s on stock suspension, went with 2.5in backspacing to push them out a little, my 32s before rubbed on the inside fenders, and now my 33s dont rub anywhere...
