backspacing
Discussion in 'The Garage' started by freakdave, May 12, 2005.
  1. freakdave
    freakdave Registered Member
    Apr 30, 2005
    17
    austin, tx
    how much for stock lift and 16 or 17" wheels.
    how much for 2 1/2" lift and same wheels.
    have heard 3 3/4 and 4 1/2, which is it.
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    There isn't a real clearance issue on the 73-91 rigs. You could run either one, it would be more preference and tire size. Bigger tires will fit better with 4.5" spacing(in away from the fenders more).
  3. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Less backspacing puts more stress on just about all of your axles' components as well. Not a big deal with 1 ton axles but it can cause problems elsewhere.
  4. freakdave
    Apr 30, 2005
    17
    austin, tx
    so a 17X8 rim with 4.5 backspacing and 265/70/17 tires will look fine and work fine (stock lift). your 2 cents.........
