Backspacing?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 85 Shortbox, Feb 15, 2002.
  1. 85 Shortbox
    85 Shortbox 1/2 ton status
    Jan 24, 2002
    138
    Grandville, Mi
    I am converting to 8 lug and am wondering what backspacing to run on 15" wheels, and how much grinding is neccesary?
    "We all gotta go sometime.... Race ya"
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1. Depends on how much you want your tires to stick out
    2. Depends on how much backspacing you use, but you're going to have to grind no matter what most likely.
    Tim
  3. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    What is the most popular offset? I don't care about grinding, just wanted to know what to look forward to. What looks better, what is more practical? Keep in mind my tires are 35x14-15 if it matters.
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    3.5" and 4.25 are the most common. I am running 3.5 and they will not require much grinding to fit. You have to do allot of grinding to run anything more than 3.5".
    3.5 is the standard for the heavy duty wheels and 4.25 is standard for allot of the more regular. I got my black 15x10's w/ 3.5" of BS from national tire and wheel (or is it wheel and tire?) for $68 each
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  5. FRIZZLEFRY
    FRIZZLEFRY 1/2 ton status
    Apr 20, 2001
    3,271
    134
    Clovis CA
    I ordered the same 15x10 8 lug wheels earlier this week from Natl. Tire.They changed their standard backspacing to 3.75 [​IMG] To get the 3.5 that I wanted it would have been $15 more per tire.So I get to play grinding boy here in a few weeks
    What do I know,Im just a Ford guy [​IMG].<a target="_blank" href=http://community.webshots.com/user/beaterwhang>community.webshots.com/user/beaterwhang</a>
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What is the backspacing on factory rally's (15x8). When I order my new rims I want to keep the backspacing near the factory specs. Thanks
    My Chevy isn't broken, its just out of gas.
  7. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    My factory rallys have 4" back spacing. Right at dead center of the wheel.
    FYI
    I bought a set of US wheels with 1" less( more positive?) backspacing and my 33" fit a lot better now. I have no lift and they do not rub even when fully flexed.
    <a target="_blank" href=http://coloradok5.com/gallery/Thunders-Blaze> Blazer pics</a>
    <font color=blue>Nevada... Where the pavement ends and the west begins
  8. 85 Shortbox
    Jan 24, 2002
    138
    Grandville, Mi
    What about load limit? They guy at the tire place acted concerned about it, but I have never heard anyone mention the issue. He also offered me rims with 4" backspacing, am I to assume that if I go with these I will be grinding a lot? Also does backspacin effect the cost of the rim? Thanks everyone.
  9. txguy
    txguy 1/2 ton status
    Sep 4, 2001
    114
    Round Rock (Austin) Tx
    Forgive a newbie, but what is it that everyone is talking about grinding? Does a 16 inch rim mean no grinding or more?
  10. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    16's will fit on a 3/4 set up..they come stock with 16's.
    <hr></blockquote>
    What do you mean, Where did I get it??...I <font color=blue>BUILT</font color=blue> the damn thing!!
  11. 72THING
    72THING 1/2 ton status
    Nov 26, 2001
    501
    Ranburne, AL
    I have a front D60 and I am running 15 x 10 rockcrawler steel wheels from 4WPW for $60 each + shipping. They are a special made 2.5" backspacing. They clear my calipers in the front with no grinding. I don't think there is much sacrifice in strength. I have raised hell and haven't had any problems yet. Hope this helps.
    Will
    '72 C10, originally 2WD, 6"Springs f+r, Dana 60 f+r, Lock-Right front, welded rear, 4.56s, 350, SM465, NP205, 39.5" TSLs, ORD crossover steering
