backup light switch adjustment
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dammit32, Oct 21, 2002.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    When I put my K5 in reverse I have to hold the auto column shifter up to get the reverse lights on. Is there an adjustment on the column or linkage or on the tranny for this?
    Its just hard to turn the wheel and hold the shifter up lol /forums/images/graemlins/rolleyes.gif
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    My truck does the same thing, so I'd be interested to know also.
    My solution so far...bought a pair of 55 watt driving lights, mounted them out back, and have them wired to a switch. It's like daylight back there when turned on. (Great for plowing - seeing as how I've got that factory limo tint)
  3. dammit32
    Jul 20, 2002
    365
    Maine
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Yes there is an adjustment, it's a module on the bottom of the steering column in the back. It's the same for the starter lock out too so make sure that you adjust it in a way you get the reverse light to work and the starter to engage both in neutral and park. It should be off by a hair since you can get the light to work at the edge of the reverse zone.
  5. Grim-Reaper
    7,385
    Atlanta
    Check your tranny mounts. If the tranny has shifted then it puts tenssion on the shift linkage. Bad cab mounts will do the same thing. I cured most of my problems when I replaced my cab mounts by adjusting the shift linkage at the tranny. Get it in Park. Chock the wheels. Loosen the adjuster nut on the shift linkage. Make sure the Tranny is centered in park. Make sure the shifter is centered in park. Tighten adjuster and see if that cures it AFTER you check for busted motor and tranny mounts.
  6. dammit32
    Jul 20, 2002
    365
    Maine
    thanks Grim
