bad bump steer
Discussion in 'The Garage' started by ilikemud, Mar 31, 2004.
  1. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    just finished doing the ball joints and rest of the front end on my 78 blazer i replaced everthing but the shocks and the 31in. tires... and now it seems to handle worse than it did before... when the wheels are straight there seems to be a dead spot before it will turn but only while moving and it has the worst bumpsteer i have ever witnessed!!! any help PLEASE!!! new steering box, no frame crack, all new tierods, wheel berrings, ujoints, seals, rag joint ok. dana 44 8 lug, could the axle have the wrong caster angle??
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Lift or no lift? Swaybar or no swaybar?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Stupid question, but did you do the work yourself, and afterwards was it aligned ? Just from what I read I suggest rechecking everything, and if it wasn't aligned , get that done . /forums/images/graemlins/k5.gif
  4. bigburban383
    bigburban383 1/2 ton status
    Dec 30, 2003
    1,242
    Michigan, Royal Oak
    Do you even have a steering stablizer on there?
  5. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    yes there is a swaybar, poly bushings. there was a dual stabilizer on there and i replaced it with a single cause both were shot. yes i did do all the work myself then had the whole front end alligned at a reputable shop. not too sure how much lift, either 4 or 6 inches... longer brake lines, and raised steering arm... stock draglink and pitman arm (everything is level)??
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Ahh yes, lifto-bumpstero, very classic syndrome on these trucks.
    The softer the spring, the more bump steer you will have.
    Depending on how your spring sits, you might/may be able to use a different combination of Z links, droped or raised arms/pitmans to get the proper angles. Even then I dont think most people can get rid of all of it.
    Which sway bar do you have, and did you use a ORD disconnect kit?
  7. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    well i am not sure what sway bar...but it is more than an inch thick and solid. as for soft springs... i have been on steel wheeled farm tractors that have a softer ride! the steering arm says skyjacker on it... i will go measure how tall it is now... but it is practically level with the pitman arm... and the steering isnt lessened when turned to one side...
  8. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    well i measured from the flat top on the drivers side knuckle to the top of the flat on the steering arm where the 3 bolts go to secure it to the knuckle, and it is a hair 3 inches tall... from the top of axle tube to the top of the steering arm where the draglink bolts is a bit over 8 inches... i am getting ready to just part the truck out and start with something new... not a disgarded project... please help if youu can!!!
  9. ilikemud
    May 22, 2003
    111
    The Farmhouse, NJ
    ?any one?
