Bad Cam
Discussion in 'The Garage' started by roadnotca, Dec 28, 2005.
  1. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    DELETE. Operator error. Good thing I don't drive a school bus.:o :o :o :o :o :o :o :o
  2. 76zimmer
    76zimmer Flyin Rat Premium Member GMOTM Winner
    Nov 14, 2005
    23,033
    1,347
    Kzoo, Mi
    Are the 2 dots on the gears lining up when you have the cam gear dot at 6oclock? If those index together, it should be correct valve timing.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,923
    333
    Fort McMurray, Alberta
    Are you sure it isn't just 180 degrees out? That isn't impossible to do, and would be far easier than calling comp cams for a new cam, lol
  4. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    I'll answer these indivually so I don't lose anything. If ya look close you can see the cam gear dot at 12:00, 90* cw from the pin "hole", which is correct like I say, Milodon timing set is correct. The cam "pin" should be at 03:00 with the next event at ~90 AFTDC is #1 exhaust valve, which is the lobe that does open #1 ex on this lump. This lump is ex #1 ~90* before the cam's index pin, should be ~90* after the pin, ie 180* out.
  5. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    So yea, I'm sure it's 180* out and now thinking back, I don't trust this stick no matter how far I can toss it; like I said at the post, it didn't have the traditional ID on the butt end either. No one can afford to take a chance on something this integral to the motor. I can wait until at least 08:00 TN time tomorrow to find out if this wasn't part of a production run of turkeys cooked-up about the end of Nov.
  6. gmtech954
    gmtech954 Registered Member
    Dec 6, 2005
    96
    ct shoreline
    remember crank makes 2 revs for one rev of cam so therefore if it was at 9 and was supposed to be at three you are on an exaust stroke not a comp stroke
  7. hack500
    hack500 1/2 ton status
    Sep 16, 2005
    523
    Templeton, Ma
    hehe, the good ol' "yeah just like up the dots and drop the distributor in at #1 tdc".... and it'll be 180* off. hehehe with dots lined up #6(iirc) is firing.:haha:
  8. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Thanks guys, koodos for helping the handicapped.:o
  9. gmtech954
    Dec 6, 2005
    96
    ct shoreline
    no prob we all have our lapses at least on this sight we could all help eachother out before we go to far off the deep end
  10. mofugly13
    mofugly13 1 ton bucket of rust Premium Member
    Oct 6, 2002
    2,813
    San Francisco
    When you solve your problem, don't go back and delete your post! Someone is gonna need that in a search a while down the road.
  11. Russell
    Jun 23, 2000
    7,923
    333
    Plus, you have a real pretty engine, and we all like seeing pretty engines!
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Now it's ready for the transplant....nurse??:D
