Bad day for my transfer case...(pic)
Discussion in 'The Garage' started by Madbomber88, Jun 26, 2005.
  1. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    Decided to check fluid in the transfer case on my 91K5 I recently purchased. It was really low, so I filled her up. Next day I notice it is leaking all over the place. It's leaking from the top somewhere and where the main rear output shaft bolts to the main body. I go to check the cause and find this...
    I am assuming it is easier to get a new (used) case than get a new housing? It is a NP241 from a stock 91K5 with automatic, passenger drop. What other year transfer cases are a direct bolt in? What would you guys do?
    Any advice is greatly appreciated.
  2. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    your going to need a t-case from a 90' or 91', they are the only ones with a electric speedo and still a passenger drop.
  3. Madbomber88
    Feb 7, 2001
    185
    Mass
    Thanks for the info. Now when I get another one, will it be easier to take the part I need of that one and put that part on the one still in the truck or do a complete swap out?
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Wait hang on those pieces look to be off the adapter. There is tranny/adapter/t-case. That looks to be the pieces off the adapter that bolt to the t-case. So you just need a adpater.
  5. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    post up pics of where it bolt to.
  6. Madbomber88
    Feb 7, 2001
    185
    Mass
    I don't have pics just yet, but let me try to explain it better. I unbolted the piece of the transfer case that the rear driveshaft slips in. The broken pieces are off the piece between that and the main transfer case. The main transfer case is two pieces bolted together. Then to the rear of that, there are two other pieces bolted, the yoke part where the driveshaft slips into and then the piece where the pieces are broken off. Probably a dumb way to describe it. I want to get whatever it is I need soon because next weekend is the only time I have to fix it for about two months...
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Ahhh...pieces off the slip yoke tailshaft housing, huh?
  8. Madbomber88
    Feb 7, 2001
    185
    Mass
    Maybe this helps. The broken pieces are off of #9 in the picture...
  9. thatK30guy
    Jan 12, 2001
    32,076
    55
    I was thinking number 11. :thinking:
  10. Madbomber88
    Feb 7, 2001
    185
    Mass
    What are my options? Does that casing slide off, or is there more to undo after removing the bolts?
  11. uglyangelracing
    uglyangelracing 1/2 ton status
    Jun 6, 2005
    271
    Rhode Island
    I have a spare blazer for parts if you need a transfer or part of it cheap just let me know. Not a member so cant see the pic.
    Uglyangl@lycos.com
  12. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
