Bad day for the 454
Discussion in 'The Garage' started by mlaux, Feb 24, 2006.
What to do with my spun rod bearing
  1. Pull the pan and replace the bad bearing
    6 vote(s)
    15.0%
  2. Pull the motor and do it right
    24 vote(s)
    60.0%
  3. Get drunk and cry myself to sleep
    10 vote(s)
    25.0%
  1. mlaux
    mlaux 1/2 ton status Premium Member
    Oct 22, 2000
    141
    9
    Rigby, ID
    So here is my sad story for the day:
    Start the truck this morning and notice a slight ticking sound. I decide it's a lifter and head for the gas station. When I check my oil its over 2 quarts low. Add a couple of quarts, filler up and head to work. By the time I get to work it's pretty obvious it's a rod bearing. The motor has 9K on it and the knock is very light so the question is... Drop the pan and replace the bad bearing or pull it and go through the whole thing?
  2. mtnman210
    mtnman210 1/2 ton status
    May 30, 2003
    3,880
    Northridge, Ca
    If it's that new of a motor I say do it right. why risk wrecking an almost new motor being lazy.
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Pull it and go through it. Bearing kits are a lot cheaper than a complete crank. If one is going it can be assumed the others are gonna follow. Also you need to figure where the oil is going.
    Ira
  4. Orange Crush
    Orange Crush 1/2 ton status Premium Member
    Mar 6, 2003
    440
    St.Stephen S.C. 29479
    Go buy a Pete Jackson noisy gear drive,install it and act like you never heard a thing.--Eric
  5. ratzila
    ratzila 1/2 ton status
    Aug 9, 2003
    691
    Mobile,Al
    :doah: :haha:
  6. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I like my gear drive!! :waytogo: If it has 9K miles and you are loosing 2 quarts of oil and have rod knock I would definately tear the whole thing apart. Ive had a bearing go and had rod knock. Was in a 69 Malibu. No amount of duct tape can fix it. Still did a couple smokey burnouts it it, cuz I just replaced tranny... Good Times. :haha: :haha:
  7. muscle
    muscle 1/2 ton status
    May 28, 2000
    408
    Show Low, AZ
    I concur...
  8. dyeager535
    26,982
    191
    Besides, the more you pull a component, the better you get at it. Pretty soon it will be old hat for you. :)
    I know I learned to pull the tranny from my car at least twice as fast as the first time. At some point it even stopped becoming a big deal lol.
  9. 79Beast
    79Beast 1/2 ton status
    Dec 9, 2001
    1,155
    Georgia
    No need to pull the engine. Drop the oil pan, roll new bearings into the rods and mains. Reinstall oil pan. Install new filter and oil. Add magnet or two to outside of filter. Run for 20 minutes, change oil filter. Cut old one open. If it traps a lot of metal, repeat the process until it comes up clean. Change the oil after the first week. Proceed with normal oil change interval after that.
