Bad Engine Vibes....?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by foxman, Jan 15, 2002.
  1. foxman
    foxman 1/2 ton status
    Oct 22, 2001
    251
    Detroit MI
    Well I've tried just about everything, and the Vibration is still there. I think though I narrowed it down to the engine/trans mounts. The engine may have developed a "miss" though it sounds fine, and only at certian RPM's in drivw will I get this vibe. This mainly occures when in 3rd or 4th gear at low speeds (engine is being bogged down) Does this make sence for me to suspect engine/trans mounts? Another few Q's, is the front driveshaft spinning even when I'm in 2wd? Will a bad front axle joint cause a vibration when not locked in 4wd? Thanks for all the help, Anything you can offer would get me closer to smoothe ridin pleasure...
    Thanx
