bad fan clutch?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by angrysnowplow, Sep 26, 2004.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Ok I've got a cold-start knock that goes away after a minute, and I know the fan clutch is bad, as it makes the same sound my blown shocks do when I wiggle the fan...
    So is it possible for a bad fan clutch to knock when cold?
    This is my '98 C3500 454 (Damnit /forums/images/graemlins/doah.gif)
  2. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    Sounds more like a lifter is bleeding down after sitting for a while, and then pumping back up when started.
  3. dyeager535
    26,977
    Easy enough fix (I would think, can't imagine a newer truck is any more difficult) to just pull the fan clutch and see. Kind of doubt it, but if it were the problem, that would be probably the best thing to have go wrong. /forums/images/graemlins/smile.gif
