Bad front tire wear
Discussion in 'The Garage' started by scoutillac, Mar 9, 2004.
  1. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    I put a six inch lift on my burb about two years ago. I have gone through two sets of tires already. They are wearing really bad on the outer shoulders. I put a 2.5 degree shim in the front to help with driveline angles. Can this wear problem be corrected with a alignment or do I need to take the shims out? /forums/images/graemlins/burb.gif If I take the shims out will grinding on the CV be enough to relieve the stress on the driveline u-joints?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your camber is most likely not correct and is causing the funny tire wear. You'll need to have it checked by an alignment shop and then put a shim between the spindle and knuckle to correct it.
    That is assuming your ball joints aren't loose.
  3. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Everything is brank spanking new. I have a hook up at the parts store. All four brand new spicer ball joints for 95 bucks. /forums/images/graemlins/peace.gif
  4. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    You have too much camber.
    The GM spec is a joke /forums/images/graemlins/deal.gif
    Mine was set at 2 and ate the outer edges up real fast /forums/images/graemlins/eek.gif
    I wanted mine set to 1/8 to 1/4 but the guy set it to 1/2
    So far looks good. I think a 1/4 would be just about right.
  5. scoutillac
    Feb 24, 2004
    423
    Spokane, Wa.
    Your camber is most likely not correct and is causing the funny tire wear. You'll need to have it checked by an alignment shop and then put a shim between the spindle and knuckle to correct it. How would I figure out what degree shim I would need so I can do the work myself and then get it aligned? Or is this possible?
  6. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    When I researched this, I found no hope. There are supposedly offset Ball joints, i dont know. Good luck!
