Bad fuel Leak. Plez Help.
Discussion in 'The Garage' started by socal chevy, Apr 7, 2005.
  1. socal chevy
    socal chevy 1/2 ton status
    Nov 18, 2004
    308
    San Clemente, CA
    The fitting where the line from the fuel pump meets the carb is leaking gas REALLY bad. I have tightened it snug, and it is still leaking the same. What should I do?... Its leaking on the manifold, and that cant be good..... :blush: What are my options? :confused: See pic below.
  2. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    replace it with a new one would be my guess.
  3. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    Teflon tape.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    I wouldn't trust teflon tape in a fuel application.
    Where is it leaking? Where the 2 fittings meet? Where the big fitting meets the carb? Or where the line goes into the fitting? Looks like the line is a little twisted and weird.
  5. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    The line itself is fine. And so is the small fitting. Its the big fitting.
  6. kyser_soze
    Sep 4, 2004
    3,180
    KC Missouri
    That fitting is pipe-threaded, which should be self sealing, it doesn't cost very much.
  7. dyeager535
    26,982
    191
    Yep, easy to remove/replace, they also make repair nuts in case the threads are stripped.
  8. socal chevy
    Nov 18, 2004
    308
    San Clemente, CA
    I see how the Large fitting would be easy to replace... but the fuel line is impossible to get out!
  9. diesel4me
    Jul 24, 2003
    17,577
    945
    Massachussetts
    gasket??
    You lose the little plastic gasket behind the big nut that screws into the carb??--without that it will leak no matter how tight it is... :confused: Those fine threads in the zinc carb strip real easy(and the carb can crack easy too,especially when forcing an "oversized" repair fitting into it..)--so be careful when tightening it..I'd refrain from running it until the leak is stopped--unless you have fire and theft on it,and dont like the vehicle..and dont mind walking home from a fire,IF you get out in time... :crazy:
  10. dyeager535
    26,982
    191
    Looks like that line is pretty much near shot anyway. Remove the end at the fuel pump (or loosen as much as possible) then try and unthread it again. Seems to work for me, the nut can twist and the line can too, at least a little bit, which is enough to break the bond there.
