Bad Howling sound
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by **DONOTDELETE**, Jun 18, 2001.
    Help, I have a horrible howling sound that sounds like it is coming out of the middle or rear of the truck, sounds like tires rubbing, or the chain in the x-fer case (208)? Could it be the rear axle (10 bolt)? It does not make the sound all the time, just often, then it will just go away, usually after I stop to let a friend out to listen. Then a few miles down the road the howling starts again, goes along with the revolution of the tires. Checked the tires and they are not rubbing anywhere.
    '84 K5
    Chevy in my blood.
  1. **Top**
    '84 K5
    Chevy in my blood.
  2. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Rotate your tires and listen to see if anything changes. Is it a shrill howl? Could be axle bearings or pinion bearing.
  3. No, more like a low howl, it is being made by something that is turning along with the wheels, even in neutral.
    '84 K5
    Chevy in my blood.
  4. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Give your drive shaft a good shake. If it moves its your u-joints. Is it at a certain rpm when it starts does it stop at a certain rpm. Does it get worse at any point?
  5. I did give it a shake and it seemed tight, the sound seems to get worse when I start slowing down after hearing it. I don't think it happens at a certian RPM, I thought it might be the drums, seeing how it gets worse when I slow down and the worst right before full stop. But however it usually does not start again when I start driving after stopping to look at it.
    It's weird, thought it might be the x-fer case also because it is chain drivin, but that is my extreem novice guess
    thanks for your help Fr8!
    '84 K5
    Chevy in my blood.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Get a longer, strong screw driver and stick it in-between the u-joints and and try and move it. Just grabbing the shaft and trying to move it by hand, may not tell you.
    <font color=green>MIKE</font color=green> - "Hukd on fawnics,werkd fer me!"
    <A target="_blank" HREF=http://www.geocities.com/emmettology101>http://www.geocities.com/emmettology101</A>
  7. fr8train
    Aug 2, 2000
    1,712
    Maryland
    Pull the drain plug or one of the lwest bolts on your case and see if any metal shaving come out. If it is the chain there would be pieces of its in there. the only problem is if the chain went then you wouldnt be moving. I learned that from experince. BTW does your truck move forward by itself easily at idle on flat ground?
  8. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    Like emmett said shaking sometimes doesn't work. I would hear this bad clicking sound, thought it was my gears, locker i couldn't figure out what it was, finally i replaced the rear u joint and it was fine then. - Doug
    Doug Krebs
  9. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    It is not a big deal to pull the driveline and give it a closer look - you can then check for binding/slop.
    Dave
    Don't Be Sexist - Broads Hate That
  10. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    if it howls even when it's idling, then it can't be anything in your drivetrain (ie., u-joints, differential)...I'd be suspect of something up front (power steering pump), or if ya know it's from the rear, either a weatherstrip/window leak, or maybe something from the exhaust (?).....if it howls when it ain't movin', it's gonna be something truly weird......just can't imagine a Tcase chain rubbin'.....JD
    Stuck?...Hell no..I still got some gas left..
  11. K5Jimmy
    Sep 21, 2000
    1,141
    Sorry....I just reread the post....I'll vote along with Pinion bearing and/or wheel bearings....seems a bad ring and pinion would make the sound all the time....I've had Ujoints make weird noises like a "travelling" sound also....I'd change them just cause they are so easy, and ya can't always get 'em to wiggle to prove they're bad......JD
