Bad Noise
Discussion in 'The Garage' started by 76blazerguy, Nov 3, 2005.
  1. 76blazerguy
    76blazerguy 1/2 ton status
    Nov 15, 2004
    125
    wichita, Kansas
    i have just installed headers, and today i had 2 super 40s put on with straight pipes and turn downs before the rear axle. And after spending all that money on the truck it now sounds like crap. There is a really bad ticking noise which is coming out of out of the pipes, it speeds up with revs and sounds really bad when you give it some gas and the revs go down. I did a little bit of searching i read that it could be the gaskets. Does this sound right? it didnt do this untill i put the stuff on. Could i have damaged something by driving to the muffler shop with open headers? Or should i just get some good gaskets?
  2. down4thakrown
    down4thakrown 1/2 ton status Premium Member GMOTM Winner
    Aug 5, 2003
    1,760
    75
    flagstaff,az
    try and go over the header bolts and collector bolts. headders usually loossen up and have to be re tightend after there first couple of miles. while your under there look for any cracks in the headers around were they meet.
  3. Russell
    Russell LB7 Tahoe Status Premium Member GMOTM Winner
    Jun 23, 2000
    7,924
    336
    Fort McMurray, Alberta
    Get some copper, or deadsoft aluminum gaskets -- They'll seal up real quick, and not blow out.
    Also, use regular exhaust manifold gaskets for the headers. They seal far better than header gaskets do, and cut the material between front port, middle ports, and rear port. This allows pipe to flex a bit, and seal up better.
    I did these three things, and my headers make absolutely no ticking noises :) Standing in my engine compartment, my engine is very quiet, just the slight ticking of injectors, air sucking through the air ducting, and the exhaust note out of the pipes :)
    Oh, one last thing -- Don't overtighten the collector bolts, or the bolts that go into the head. You'll warp the flanges in a real hurry! I spent hours straightening mine out after making that mistake :S
  4. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    k thanks, i really hope it goes away after the new gaskets. Its annoying! Are summit copper gaskets ok?
  5. Russell
    Jun 23, 2000
    7,924
    336
    copper is copper, I'd imagine they'll work. I used Mr.Gasket myself, but thats just cause what pepboyz on crack had (aka, Canadian Tire)
  6. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    i used manifold factory style gaskets. worked great.
  7. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Don't use the thin copper"racing" gaskets for the head. They are too thin and your headers will leak worse.
  8. keifer
    keifer Registered Member
    Nov 1, 2005
    16
    MD-Phoenix someday
    I have very good luck using header gaskets with high temp rtv on both sides,
  9. 76blazerguy
    Nov 15, 2004
    125
    wichita, Kansas
    i put new coppers ones on today and tried the rtv. and its still making that noise. What should i do now? I checked the collectors to
  10. sweetk30
    Nov 1, 2004
    25,546
    542
    :confused: :doah: :eek1:
