Bad Oil Guage
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazinRojo, Jun 23, 2003.
  1. BlazinRojo
    BlazinRojo 1/2 ton status
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    Alright, my '83 oil guage went bad. Reads a constant 15 psi when the engine is running, even when removed from panel and wired directly to oil sender and battery (in case of wiring problem). The only problem is, GM discontinued the guage last year. Any ideas as to where I can get one? Could I find a shop that could repair it? Anyone have a spare guage lying around?
  2. DOCKAWI650
    DOCKAWI650 Registered Member
    Sep 29, 2002
    61
    Gboro, NC
    I have an 82 diesel, and just ordered a whole gauge cluster and gauge bezel off ebay for under $60. check there, im sure you could find somehthing. Or if you have to, you could get an aftermarket gauge.
  3. midnight473
    midnight473 Registered Member
    Jun 4, 2003
    21
    Grayling, MI
    I just replaced the motor in my 88 and broke my oil sensor when I tried to pull it off the old motor. It was recommended to me by the engine shop I got the motor from to put in a mechanical gauge (I bought one from Carquest for $20.00) as they are more accurate and eliminates another electrical connection.
  4. BlazinRojo
    Mar 29, 2001
    111
    San Luis Obisbo, CA
    yeah...but I'm trying to maintain the stock appearance....if push comes to shove though, I'll put a mechanical one in the cluster
  5. dyeager535
    26,978
    don't need to get into electrical vs. mechanical debate, but recent testing is showing that electric gages are every bit as accurate as mechanical.
    Besides, you are just trading a wire that carries electricity for a tube that carries oil. I think I'd rather fix a wire.
  6. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I am with you on this one.
    I hated the mechanical ones for that, they brake a line and you can't fix them.
