Bad Rear End ::Help:: *DELETED*
Discussion in 'The Garage' started by TruckNutzDude, May 4, 2003.
  1. TruckNutzDude
    TruckNutzDude 1/2 ton status
    Mar 31, 2003
    3,532
    Agawam, MA
    Post deleted by TruckNutzDude
  2. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    Re: Clunking Rear End ::Help::
    Pop the driveshaft out and throw some grease down the shaft that goes to the transfer case. Sometimes that is the culprit.
  3. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the u-joints 9 out of 10 times thats what it is /forums/images/graemlins/thumb.gif
  4. Can Can
    15,555
    149
    Cochrane, Alberta, Canada
    Like Bubba said, chances are the clunk is coming from your slip joint.
    You should also check out all the crossmembers underneath the truck. If one is loose it will allow the drivetrain to shift around.......
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    If nunna that stuff works check the spring perch where the spring pack bolt fits in. My blazer had the same problem as you. It turned out the hole in the spring perch elongated by an inch and the bolt was running back and forth. The only way to fix it was slap in a 14 boltff /forums/images/graemlins/shocked.gif /forums/images/graemlins/cool.gif
  6. TruckNutzDude
    Mar 31, 2003
    3,532
    Agawam, MA
    Re: Bad Rear End ::Help::
    U-joints checked out OK, slip yoke is OK, gears in diff... BAD. Is anyone selling a good 10 or 12 bolt rear cheap??? I'm only running 32's for now so I don't need a 14 bolt (yet). /forums/images/graemlins/rolleyes.gif
  7. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    How can I check for that without taking the cover off? Or am I just going to have to tear the thing apart and check the teeth?
    your just going to have to take it apart and have a look /forums/images/graemlins/shocked.gif
