bad sensors
Discussion in '1992-Present Chevy & GMC models' started by steve_97, Mar 20, 2002.
  1. steve_97
    steve_97 Registered Member
    Feb 27, 2002
    25
    Boise, Idaho
    I was wondering if the computer does not give any service codes, does that mean all of the sensors are good or can there still be problems? 94 chevy 4x4.
    thanx
  2. Shorts
    Shorts 1/2 ton status
    Oct 16, 2001
    336
    CC & SA, Tx
    usually if a sensor goes bad, it'll trigger a code. thats due to the fact that the sensor is no longer taking a reading that is consistent with the previous readings.
    one sensor that usually draws a phantom code is the EGR.
    if you want, you can run the codes anyway and see if there's anything stored. if not, then you don't really have anything to worry about. the sensors are still in good enough condition that the truck is getting consistent readings.
  3. steve_97
    Feb 27, 2002
    25
    Boise, Idaho
    thank you, i already ran the codes, it came up good. I was just wondering because it seems like i have less power. might need new wires, but plugs are new, also getting like 12 mpg in town.
    thanx
  4. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    02 swnsors dont always set off a code, but can be bad.
  5. Shorts
    Oct 16, 2001
    336
    CC & SA, Tx
    i second what desertdueler said about the O2....you might wanna replace that and see what happens. also, your cat might be dead as well.
  6. steve_97
    Feb 27, 2002
    25
    Boise, Idaho
    Catco stainless Y-pipe and cat from summit along with a new o2 sensor is already in the plans. The help is always greatly appreciated. I'll post in about 2 weeks to let everyone know if it helped.
    thanx
