bad short
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by dbltapp, Aug 30, 2001.
  1. dbltapp
    dbltapp 1/2 ton status
    Apr 25, 2001
    133
    Maine, but moving again.
    every time i hit my rear window deffoger, the truck about stalls then is fine. is this an easy fix? can the whole shootin match be pulled out? HELP!
    "Luck, often enough will save a man, if his courage holds"
    89 SUBURBAN, 1/2 TON, 350 TBI,21/2 LIFT W/33'S
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Hook up a voltmeter to the battery and see what happens when you turn on the defogger. Sounds like the voltage is dropping so low that the engine isn't getting enough electicity to run properly. Could be that you alternator is not working as good as it should.
  3. OneLeft
    OneLeft 1/2 ton status
    Aug 14, 2001
    111
    Colorado USA
    I have a bad short as well. All mine does is drain the battery over night to the point that it wont start. The battery holds a good charge on its own, and the alt is working fine. But when I leave the battery hooked up over night, its dead in the morning.
    OneLeft
    http://coloradok5.com/gallery/OneLeft
  4. dyeager535
    26,975
    Might try pulling fuses one at a time for overnight, see which circuit it is. Can't hurt, easy to do.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
  5. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>OneLeft check your ciggerette lighter/radio memory circuit. This is a constant 12v and shorts out a lot.</font color=blue>
  6. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    ditto on cigarette lighter....very very very common problem
    1985 GMC C-10 Shortbed
    1984 Chevy K-5 Blazer
    1982 Chevy C-10 Longbed
  7. dbltapp
    Apr 25, 2001
    133
    excuse my stupidity, but how would the lighter tie into the defroster, and what would i need to do?
