Bad tranny mounts cause vibes?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, Sep 2, 2000.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    When i first take off in my truck will shake just a tad (SM465) and then when i get going about 35+mph it shakes again when i let off of the gas pedal, or hold the pedal in the right spot i can feel it in the pedal and through out the truck. My rear ujoint down by the axle i can move it (looks like it is missing the round clips on the sides of the joint and if it had both of them back in place to make 4 clips it would stop moving) Any way the tranny shop i have been taken it to said that the vibes are coming from my tcase mounts (which are very bad) could this be causing the problem + the joint in rear. Or does it sound like all of the above + bad angles?
    Thanks Allot!!!
  2. Depdog
    Depdog 1/2 ton status Author
    1,657
    Georgia
    Re: Bad tranny mounts case vibes?
    The u joint sounds like your culprit, its also a cheap fix to replace it. If it does not work, your not really out anything, shounds like it needs replacement anyway.
    Depdog
    <font color=blue>"Lead, Follow, or BECOME the Trail"</font color=blue>
    http://depdogsk5.coloradok5.com
  3. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey all,
    I have an th-350 in my blazer and it's mounts are so bad it makes the front driveshaft rub on the tranny crossmemeber. My question is, when I replace these, I assume that i should support the transfer case with one jack and the tranny pan with another ?? Please help !! I can't use my 4wheel drive with out these fixed !! Should i remove my driveshafts ?
    Blake
  4. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Impex I am going to second the notion that your u-joint is the problem.
  5. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    I had a really bad vibration in my 83. I replaced my u joints, had my drive shafts rebalanced, nothing helped. I finally lowered my t case (I recently installed a lift kit) and had the wheels balanced and it all went away. Like the guys said, replacing the u joints is worth the few bucks it costs, but I'm willing to put my money on tire balancing, good luck!
    creepin' and crawlin'
    Jim
  6. Impex
    469
    Chandler, AZ
    Well i know its not the tires because i just bought the goodyear muds from Moose and my friend balanced them at discount tire really good and it took out some vibe but not the one when i take off in 1st. and my t-case knob rattles like crazy also
