bad u joints
Discussion in 'The Garage' started by TxK5Blazer, Jan 7, 2004.
  1. TxK5Blazer
    TxK5Blazer 1/2 ton status
    Aug 13, 2000
    593
    Floresville, Tx
    Hey guys I don't have much time and will check this when I get home I am out of town right now but would bad u joints make the drive shaft vibe. they are faily new less than a year old but have been wheeled semi hard. need some opinions?..........Jason
  2. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    yes they can. I've had it happen more than once. /forums/images/graemlins/thumb.gif
    Rick
  3. K5Jimmy
    K5Jimmy 1/2 ton status
    Sep 21, 2000
    1,141
    Lake Dardanelle/Logan Co, Ark
    Just a thought,but if you are out of town and driving your truck...I'd check 'em out now...if you drive your truck at highway speed, the bearings can potentially eat themselves in a fairly short distance...I once felt a bad Ujoint on the way to work...figured I'd drive home (13 miles) going slow and easy...only Had to hit the freeway for about 3-4 miles...I'd pussyfoot and get 'er home to fix it...all went well until I eased off the gas to make my exit, and the rear shaft disassembled itself at the TC end...lucky it was a 203 so I was able to pull the shaft (on the shoulder of a Dallas freeway) and make it home...my 20 minute $15 U joint cost me $200 for a new shaft...never mind that when it let go I like to have sh!t down both legs.....coulda been worse... /forums/images/graemlins/1zhelp.gif
  4. mr_fujisawa
    mr_fujisawa 1/2 ton status
    Sep 1, 2003
    288
    SF CA
    from what i understand the u joints will make some noises first, then it will vibrate upon driving, then the u joints go kabloowie.
    i just changed my rear u-joints, i was hearing a squeaking noise. i pulled out the u joints and pulled the cap of of one of the crossmembers. there were no needle bearings in the cap at all and the cross member was ovalized. /forums/images/graemlins/shocked.gif
    good luck /forums/images/graemlins/thumb.gif
    sean
  5. TxK5Blazer
    Aug 13, 2000
    593
    Floresville, Tx
    sorry to confuse you guys the truck is at home I am in a company truck here at school so I will check mine when I get home on sat. may just replace the u joints anyway...Thanks guys
