BAD VIBE
Discussion in 'The Garage' started by screamer*145, Feb 9, 2004.
  1. screamer*145
    screamer*145 1/2 ton status
    Oct 23, 2003
    174
    cottage grove, mn
    Ok maby you guy and gals can help, so heres the problem drivin home from work and everything is fine then all of a sudden I get this realy bad viberation got home made sure the motor was not doing it it was fine so my next thought was a u-joint blew but it could'nt be because the fornt end was disingaged so it was not spining there fore could not cause a vibe, do you think that i tire weight could have pop't off because it starts when i get above 30 mph.
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    so let me know what you think because I would like to know what to look for and what to do first so please help?
    /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/1zhelp.gif
  2. 4by4bygod
    4by4bygod 1/2 ton status
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Hello!
    It could be a wheel having gone out of balance, but I would check the rear shaft u joints too. Also, jack up the front end and tug on the wheels. I once moved my front wheel back and forth a few inches, turned out to be a wheel bearing that had gotten screwed up.
    Tom /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    Hope the rear diff isn't losing a pinion bearing, or maybe a tire seperating?
  4. 4by4bygod
    Nov 13, 2003
    3,859
    With My Tinfoil Hat
    Looking at the pinion is a good idea.. on my 87, I finally cured a vibration I had by just getting a new pinion yoke put on. I would have done the bearing next, if the yoke itself wasn't the problem. Turns out, the yoke was worn so bad on one side that the u joints bearing cup wouldn't seat right, thus killing the joint prematurely.
