Bad vibes at higher speeds. Possibly alignment?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Paxx, Feb 25, 2004.
  1. Paxx
    Paxx 1/2 ton status
    Feb 9, 2003
    1,405
    All Over Western Canada
    When I hit about 75 km/h I start to get some vibration that seems to be coming from the front end. It gets worse if I try to speed up any faster, to the point where I already shook loose a rad mount.
    Is this my alignment? Tire pressure is even, and this is a newly developed problem. Any help would be welcomed.
    Thnx
    ~Max
  2. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Possibly you threw off a wheel weight?
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    My lower ball joints are bad and i get this similar shaking, and extreme tire wear too. floating steering, ok, maybe not quite the same as yours,,,, /forums/images/graemlins/grin.gif
  4. rcpilot
    rcpilot 1/2 ton status
    Feb 22, 2002
    507
    Central Cali
    Like teh above folks stated, check balancing weights, get the truck on a jack/lift and check for loose balljoints, tie-rods and wheel bearings. If all checks then check your frame right behind the steering box to see if it's cracked, also check steering gear and drag link for play.
    Have you recently hit a curb or something??
