Bad vibes
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by hpfire7227, Mar 14, 2000.
  1. hpfire7227
    hpfire7227 Registered Member
    Mar 14, 2000
    75
    Holland Patent, NY
    Here it is: Vibration (mostly felt in the wheel) between 45 and 65 mph in my stock '89 w/ 32x11.50x15's. New u-joints installed w/ no results. Assuming tire/wheels are all balanced, what else is there? My ball joints need attention, but would they be capable of causing such vibes?
    if the tire fits....it's too damn small
  2. SVBlazer
    SVBlazer 1/2 ton status
    126
    Boxford, MA
    Could be a number of things: busted motor mount, busted trany mount, bent rim, might have lost a tire weight on the trail, could be a separated tire and might have bent the drive shaft. If the vibration is reduced above 65mph or so sounds like tires.
  3. Goose
    Goose 1/2 ton status
    1,127
    South Central Kansas
    From what I've heard, yes, your ball joints can cause that vibration. I'd start there.
  4. **b**
    **b** 1/2 ton status
    279
    KIllington, VT.
    agree's w/ Goose
  5. hpfire7227
    Mar 14, 2000
    75
    Holland Patent, NY
    Thanks for the help guys! I'll start w/ balancing the shaft then do the ball joints. I'll keep you posted.
    DAN THE MAN '89 SILVER SILVERADO
