Bad Vibes!!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tigerk5, May 27, 2003.
  1. tigerk5
    tigerk5 Registered Member Premium Member
    Aug 5, 2002
    82
    Jacksboro, TX
    I have a problem. While driving on the road, acceleration is no problem. When I let off the gas I hear a roar from under the truck. I can't determine if it is the rear diff or the transfer case. Anyone have any ideas?
  2. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    Check your u-joints.
  3. georgiared84
    georgiared84 1/2 ton status
    Sep 5, 2002
    487
    Austell, Georgia
    If it doesn't end up being your u-joints, check your rear diff fluid. That roaring on decel sounds like it may be your carrier bearings.
  4. tigerk5
    Aug 5, 2002
    82
    Jacksboro, TX
    The U-joints are fine. That was my fist thought as well. I am going to pop the cover tonight to have a look at the rear diff.
  5. txbluethunder
    txbluethunder 1/2 ton status
    Jan 29, 2002
    835
    Austin, TX
    did you drop your t-case or extend your drivelines when you did your lift? if not it could be slop in the slip yoke. mine did that with a 2.5" lift.
  6. tigerk5
    Aug 5, 2002
    82
    Jacksboro, TX
    I did drop the t-case when I put in the lift. I just started about 2 weeks ago. It is driving me crazy!
  7. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    betcha 10 bucks you'll find metal in that diff fluid. /forums/images/graemlins/eek.gif
  8. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    BTW, if you do need a set of diff carrier bearings, let me know. I've got a set of motor city ones with races you can have. I bought them last year for the next time I rebuilt my 84 ten bolt and ended up replacing the whole rear, so I don't need them.
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    From what I've had experience with... and trust me i had the same problem. Its 1 of 2 things. Tcase Chain... if it has slack, upon decell it will do that. or in my case it was the driveline angle at the tcase. I got a CV shaft and no more vibes at all. No more roaring on decell, etc.
  10. tigerk5
    Aug 5, 2002
    82
    Jacksboro, TX
    Spent a lot of quality time with the Blazer tonight. Have decided, with the help of of other Blazer fans, that the noise is coming from the t-case area. I get the noise a little on acceleration, and more on decelaration. If I slide it into N going down the road, I get it all of the time. Any more advice? BTW thaks for all of the responses!! I appreciate all of your experienced input, and your volunteering of parts!! It makes me proud to be a memeber of the K5 community!!
  11. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    Hey, let's start doing guess that problem pools. We each put up $2 and name what we think someone's prob. is. When they finally get it apart and post the result, the closest one gets the pool. (OK, I know we have some guys in blue here, so notice the laugh pics I'm about to put) /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    I'm still bettin driver's side carrier bearing. (even though it sounds like it's coming from farther forward.)
    Let us know when you figure it out.
  12. tigerk5
    Aug 5, 2002
    82
    Jacksboro, TX
    I will do that. Tonight I plan on popping the cover. If you are correct, I will have a beer in your honor. I will also email you one. What's your flavor!
  13. georgiared84
    Sep 5, 2002
    487
    Austell, Georgia
    did you get it figured out?
  14. tigerk5
    Aug 5, 2002
    82
    Jacksboro, TX
    At this point, I have been living with the vibes! I am using the K5 often this time of year! Hopefully I can break her down next weekend.
  15. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    I seem to have this same exact problem as you describe.
    I found my rear driveshafts slip yoke has wore through the plastic /forums/images/graemlins/angryfire.gif they put on the splines.
    I too tried changing the U-joints with no luck.
    Good luck with yours.
  16. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Have you figured it out?! cause I get the same problem!
  17. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    One more thing to consider is the pinion bearing.
    Easy to check, just grab the pinion yoke and try and shake it up and down.
    That was my problem.
  18. frank8808
    frank8808 Registered Member
    Jul 20, 2002
    15
    San Diego CA, USA
    I have the same problem. Had the Diff Checked.(No Problem) Had the u-joints replaced.(Still the same noise) I think it's the Transfer Case. I'm going to take it to the shop next week. It's somthing I did'nt have to much experince with.
