BAD VIBES
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by REDNECK, Jan 5, 2001.
  1. REDNECK
    REDNECK Registered Member
    Feb 23, 2000
    26
    I have a bad vibration coming from the rear of my blazer. I also notice a squeak that increases with speed. The vibration starts at 35mph and just gets worse the faster I go.Could this be a wheel bearing? I also have a 12 bolt rearend with a gov-lock and I wandered if it nroke a tooth or something if this would cause this problem. The truck is all stock with 33's. Whatever it is it only happens when I accelerate, not when I'm coasting down a hill.
  2. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    Check the rear u-joints. This sounds about like what happened with my old Blazer. As for the squeaking, I can't tell you what that might be.
    "Don't hit me with them negative waves so early in the morning." Odd Ball--Kelly's Hereos
