Bad Vibration
Discussion in 'The Garage' started by Lance, Jul 5, 2002.
  1. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    Anybody got any ideas on what might be causing my Jimmy to vibrate like a paint shaker at highway speeds (55 - 70). You can see the vibration in the steering wheel, but I think I can feel it through the rear floorboard too. I have replaced all of my rod ends, all of my u-joints, had the wheels inspected and balanced, but none of this has eliminated the vibration. The tires I am running on the street are 33X12.50x15 BFG AT's which is not a gnarly tread pattern at all, so I don't think it is the tires. I have considered that it might be either the wheel bearings (no noticable noise) or the driveshaft(s) (no noticable dents or damage and the weights are still there). There is no play in the tire/wheel when I lift the tires off the ground either, so I don't think it is the ball joints. But then again, it could be any one of these things, a combination of the three or none of them at all, I am just not sure. Anybody with some insight on what might be my problem?
  2. BowtieBlazer
    BowtieBlazer 1/2 ton status
    Jul 15, 2001
    2,462
    Baton Rouge, Louisiana
    is your yoke in decent shape? Good u-straps? This can not hold teh u-joitn firm. trying gettign under the truck and movign the u-joints back and forth up and down side to side wahtever...if there is any play whatsoever this can vibrate
    Next inspect front wheel bearings and calipers that they are nt sticking...bet its a u-joint though....GOOD LUCK!
  3. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Hmmmm, Motor/t-case mounts maybe? Ball joints worn exxcessively? You've checked the bolts on the steering box? Checked the drag link ends, tighened all bolts ect ect? Let us know what ya find.
  4. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Check the yoke to the TC and axles. If the big nut that holds them on are a litle loose then that will cause it too. Also make sure your drive shafts are phased right too.
  5. thatK30guy
    Jan 12, 2001
    32,076
    55
    Loose nut behind the wheel? /forums/images/icons/tongue.gif /forums/images/icons/laugh.gif
  6. K05Aggie
    K05Aggie 1/2 ton status
    Feb 22, 2002
    136
    Dallas, Texas
    My Blazer vibrates at all speeds because the transfer case output shaft is bent.
  7. bigoltrux77
    bigoltrux77 1/2 ton status
    Jun 12, 2002
    318
    Fort Polk, LA
    mine vibrated alot too, then i dropped the driveshaft bc the u joints blew..fix those b4 they go out..trust me.
