bad vibration?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Hank75, Aug 27, 2002.
  1. Hank75
    Hank75 Registered Member
    Nov 30, 2000
    31
    i need your help. my 75 blazer has developed bad vibration and squealing type noise upon aceleration. the noise randomly occurs after that, the shakes only upon using the gas pedal. specs 350 t350 203 D44 12bolt 4:10
    both gearsets new last summer.
    what is going on??????
    thanks
  2. 77blazin
    77blazin 1 of a kine K5
    Mar 31, 2000
    394
    Honolulu Hawaii
    Recheck your mounts and see if they are loose, bad vibrations could be coming from not setting the mounts correctly, or forgetting to tighten one or more bolts.
    The bad squeal could be from your belts on your engine, recheck the tension on your belts, that could be your problem.
    Mike W.
