bad vibrations
Discussion in 'The Garage' started by carolina k-5, Mar 28, 2005.
  1. carolina k-5
    carolina k-5 Registered Member
    Jan 20, 2005
    58
    columbia, S.C.
    i installed the lift kit at my shop at the family farm. drove it home brakes werent quite tight enough, other than that it ran great. blead the brakes again now theyre fine. but now its vibrating my fillings out of my teeth. it stops when i let off the gas and coast. could this be u-joints? any constructive comments greatly appreciated.
  2. nerraw117
    nerraw117 1/2 ton status
    Jan 5, 2005
    788
    charlotte, NC
    no a pro, but if someone else will chime in. but i think it might be because of your driveshaft angle. how much lift did you put on?
  3. mxfireman
    mxfireman 1/2 ton status
    Dec 7, 2002
    2,480
    LHC, AZ
    Try doing a search this topic has been covered numerous times in the garage. :D
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    I had the same type of vibs. , it was the rear u-joint failing (no lift)
  5. carolina k-5
    Jan 20, 2005
    58
    columbia, S.C.
    i only put 4" lift on it, and it drove fine for about an hour the angle doesnt look bad.
  6. carolina k-5
    Jan 20, 2005
    58
    columbia, S.C.
    thanks i just got home with 2 new joints. im gonna crawl around in the driveway. ill let you know how it goes.
  7. carolina k-5
    Jan 20, 2005
    58
    columbia, S.C.
    yep u-joints. "like butta"
