bad wiring
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by balazerjake86, Oct 30, 2002.
  1. balazerjake86
    balazerjake86 Registered Member
    Oct 30, 2002
    41
    clarksville,tn
    my 86 4x4 has a bad wiring problem. whenever i turn on the headlights the fuel gauge goes dead and the right turn signal indicator comes on. would it be easy to re-wire it or just to take it all apart and look for a bad ground. also the temp gauge does not work or the ampmeter
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Sounds like your dash cluster has some bad wires. I noticed some of mine had burned the traces out. I simply re-soldered in some wire. All is well now.
    Also check your light sockets, and the dash cluster connector. I found my connectors were VERY dirty - go figure /forums/images/graemlins/thumb.gif
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    You have a missing ground under the dash.
    That is exactly what happened with me when I put it back together after a frame off restoration. It took me a couple of weeks to figure it out /forums/images/graemlins/frown.gif
    It should be eiher a broken wire, not connected wire or just a bad contact area. If you don't find anything loose, try and take off the ground near the ebrake pedal and clean the surface and tighten it back.
  4. balazerjake86
    Oct 30, 2002
    41
    clarksville,tn
    thanks all i bought it from a guy that had a radio installed by an idiot and he said it started after that. also i noticed that when i hooked up my radio i could not find a memory wire i used a wiring harness from auto zone and it came with one big connector that held three seperate plugs from the truck but then they also gave me a male plug in with two wires and i did not see any where for it to plug into. any ideas or was it just an extra part for a differnt chevy
