Baffled over shock installation, need help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Madbomber88, May 16, 2002.
  1. Madbomber88
    Madbomber88 1/2 ton status
    Feb 7, 2001
    185
    Mass
    For my 90 stock K5 with dual shocks up front... I bought Pro Comp ES3000 all around. Installing the fronts, I can't get them both bolted in because they hit each other at the bottom. I can get the tops in fine, but the bottom of the shocks hit each other. Anyone else run into this problem? I called summit to make sure they gave me the right part number, and they are sure they did. Do I need to put more spacers in? Please advise. And if like it has been recommended before to leave one off to enhance ride quality, which one should I leave on? Thanks in advance.
  2. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    Youll need about an inch space inbetween the the two bottom shocks.
  3. fright89
    fright89 1/2 ton status
    Sep 27, 2001
    279
    boston
    I think mine had a spacer. Just got singles now.
  4. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Mine did that too, took one off to fix it, and realized you are better off with single shocks in the front...
  5. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    if u dont have a real spacer, u can just take a bushing for your shock (if its hourglass shaped and poly) and cut it in half, and u got a good spacer.
