baffles...corect? pic
Discussion in 'The Garage' started by broncoman6524, Mar 8, 2007.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    is taht right or is it the other way? i bought these with em already installed and idk if this is correct...
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I can even tell what is in that picture, its so fuzzy.
  3. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    ok ya it is a ****ty pic..lookin down on the cover...the baffle is a U basically...althioygh its a square...with the lines...(upper part of U) poiting up, OR towards rocker arms when installed..leavinga 1" wide gap between baffle top adn grommet
  4. 4X4HIGH
    Dec 14, 2001
    22,062
    69
    Pleasanton, CA.
    It needs to be installed so the "U" points towards the valve cover and shrouds the grommet so it won't suck oil.
    Pretty sure if you tried it the other way the baffle would hit the rocker arms when you try to install the valve cover.
  5. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    actually...it dont. lol. when i bought these the dumbass whoever ahd em first...put em on that way. any suggestoins on how to fix this?
    if you cant tell/dont know. theyre held on by studs that you hammer into holes...
