baffles in an edelbrock carb?
Discussion in 'The Garage' started by 85 Jimmy, Dec 2, 2006.
  1. 85 Jimmy
    85 Jimmy Sheepdog Premium Member
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    does anyone know if there is a kit out there to put baffles in an edelbrock? or is the only solution to my incline problems going to be either a q-jet or FI?
  2. 84 K5 4x4
    84 K5 4x4 1/2 ton status
    Nov 14, 2006
    163
    Jasper Ga
    I dont know about baffels but there is a spring loaded needel and seat that you can get i got one in mine and it does great on hills
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    if you'd like to eliminate the problems you're having with your AFB carb off camber, install it in one of these...
    [​IMG]:deal:
  4. slider
    slider 1/2 ton status
    May 7, 2001
    547
    Whidbey Is. Washington
    spring loaded needle and seats work great, easy install, any idiot that owns a holley would screw it up:haha:
  5. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    A 7* marine wedge will work just fine.
  6. 85 Jimmy
    Dec 31, 2005
    1,913
    69
    Gulfcoast
    anyone have any part numbers?
  7. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
    wow i didnt know i could do that to my edelbrock. thats cool, so who has the write up??
  8. Mad-Dog
    Mad-Dog 1/2 ton status
    Mar 20, 2005
    548
    Ocklawaha,Fl
    not sure exactly what problem your having but if the fuel is coming back up thru the float vent when traversing steep inclines you can take a length of vacuum hose and connect the 2 float vents together, then drill a couple holes in the line close to the threaded stud to allow the pressure to equalize in both float chambers.
  9. Slapperbar
    Nov 29, 2005
    2,747
    3
    We used the wedge in Hawaii with great success. Any marine shop will have them. They're used to keep the carb level when the boat is on plane/ step.That and I think I remember we epoxied the vents. I think. Thou the Holley rubber tube might work also.
