Balancer
Discussion in '1982-Present GM Diesel' started by longbedder, Jan 8, 2007.
  1. longbedder
    longbedder 1/2 ton status Premium Member
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    After googling quite a bit, it seems that the crank failures that exist with the 6.2's are tied (at least partially) to harmonic balancer deterioration. Are you guys running GM or aftermarket balancers, and if so which ones (with part numbers, please)?
  2. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Do you need balancers for the one I sold you or the one in the other truck?
    I have 3 clean balancers I will sell cheap.
    :D
  3. diesel4me
    Jul 24, 2003
    17,546
    937
    Massachussetts
    Good question!..
    I was wondering if any better balancers than the stock style are available for a 6.2 also..like a "Fluidamper" one,etc..never see any mentioned for diesels in Jegs,etc...:confused: --if I bother to replace mine someday,I'd rather use one better than OEM of possible..
    :crazy:
  4. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    I personnaly haven't heard of any replacement aftermarket like the fluidamper.
  5. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    That's mostly what I was interested in: aftermarket improvements. I sure haven't found any in my research.
    Thanks, iceman, but the one that's on there actually looks pretty good. :D
    Now if I could only get some free time to get it in the truck and running. :rolleyes:
  6. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    The following is an e-mail response to a question I sent to Vibratech, which manufactures Fluidampr products.
    "I do understand the crank problems on the 6.2L & 6.5L engines which is why we are currently developing a Fluidampr that will work on the late model 6.2L & 6.5L engines. This Fluidampr will also work on the earlier 6.2L engines however the damper will need to be spaced out about 5/8" between the crank gear & damper. The stock damper on the earlier 6.2L engines had a longer hub. The part number is 800141 and hopefully will be available in 6 to 8 weeks."
    By the way, the GM part number for the OE damper is 14022671, if anyone is interested.
  7. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    I thought I read somewhere that Power Products was making one too.
  8. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Bully Dog also makes a fluid damper for the 6.5L. That being the case, I now assume you could just space it out 5/8" and it would also work on the early 6.2's. Part number 63101.
  9. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I don't think either one is shipping yet. Other than a part # I haven't found any info on the Bully Dog either.
  10. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    could you post the part #, if you have it.
  11. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    Look two posts up, dood...
  12. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    The Bully Dog is made by Fluidampnr, only the stickers are different. Shipping won't be until Feb.:(
  13. ccatlett1984
    May 1, 2005
    161
    michigan
    Der, oops guess I just didn't see it.
    BK, did they give you a price for the damper once it ships?
  14. longbedder
    Oct 26, 2005
    4,193
    359
    Ridgecrest, CA
    I didn't get an exact price, but they're sure proud of it: it's gonna be $300-$400 :eek1:
  15. uglytruk
    uglytruk 1/2 ton status
    Oct 24, 2004
    1,329
    IN A JUNKYARD, UNDER A TRUCK*N E Rust Belt
    I havn't noticed any deterioration on my dampers, just my well publisized crank pulley...
  16. BKinzey
    Jan 13, 2006
    3,145
    Hollywierd, CA
    I've heard price will be as mentioned 3- 400. I'm getting one. One of the "extras" I figured would be good for my build. I can also wait another month or two for them to come out as my build is in pieces:rolleyes:.
