Balancing 33's
Discussion in 'The Garage' started by 78Suburban, Nov 18, 2005.
How do you balance 33's?
  1. Lead weights on wheels
    19 vote(s)
    79.2%
  2. Golf Balls
    0 vote(s)
    0.0%
  3. Some other Blancing Media
    5 vote(s)
    20.8%
  1. 78Suburban
    78Suburban 1/2 ton status
    Jul 4, 2005
    2,609
    Georgia
    What is the best way to balance 33" TSL, Bias tires on stock 16.5x6.75 wheels?
  2. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    Balancing beads for sure.
  3. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    33s should balance out fine with weights on the wheel, get a good normal balance done like that.
  4. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Lots of lead! Pound-on weights are the best to balance. better weight placement......
  5. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    cool, guess I'm looking at getting a tireshop to mount my tires and balance them..... I hope they don't throw a fit about putting 12.50 tires on a 6.75" wheel :p:
  6. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    you the weigth that stick to the flat part of the wheel. ive never had good luck keeping the ones that hammer onto the lip they always seem to fall off after offroading. ive never had the ones that stick to the wheel do that though. 33'' will balance out fairly easily
  7. KTEX
    KTEX Registered Member
    Nov 8, 2005
    19
    wylie
    The best balance possible is to find a shop with a roadforce balancer,it takes a while,but basically the machine will find the heavy spot of your tire and heavest wheel spot.you reindex the tire to wheel for the best balance.wheel wieghts are fine.
  8. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    roadforce balancing shouldn't take much if any more time then a n ormal balancer. The one we had at school was quick and easy.
  9. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Hammer weights are fine as long as you keep the off of rocks. Stick ons ar better unless you see alot of mud or deep water. Golf balls are too big for a 33 on a 16.5. Airsofts BBs are nice, but I think they are over kill for a 33. If those were mine I would go hammer ons and keep an eye on the weights after wheelin.
  10. ProJunkRacing
    ProJunkRacing 1/2 ton status
    Jun 20, 2005
    1,229
    FrankFort IL
    hammer ons honestly might be kinda hard on a wheel that narror because of how wide the tire is I once was told to balance some tires 33/14.5/15 on a ranger , and the rims were 8" wide , and i couldn't even get a weight on it because of the tire stickin out so far told the customer we couldn't do em
  11. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    so hammer ons might not fit on this wheel/tire combo?
    I wonder what would happen if I didn't balance them at all? :
  12. fireplug
    May 3, 2005
    1,692
    Toronto, Canada
    I'm really surprised that more guys aren't supporting 'beads' they don't get knocked off in the mud or water or anything and work great. I had them in my 33's before I went to 37's and they fixed my square tires. I don't have them on my 37's yet but I will.
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    you may have to go to a little mom n pop or crackhead type of tire shop to mount those 12.5's on those narrow rims,,,some of the bigger corps like Big O or Discount may not want to deal with it,,, claiming a saftey hazzard or something.
    i usually get all my "iffy" work done at the local crackhead tire shop, and is usually much cheaper.
    just make sure you hang around and kinda watch the work they are doing. :D
  14. JIMs70K25
    JIMs70K25 1/2 ton status
    Dec 31, 2001
    524
    Chesapeake, VA
    I had 33" tsl bias plys and they were a pain in the butt to balance and didn't hold it well as the tires cupped/wore real bad. I only had 11000 miles on them when I got rid of them. I kept an eye on these, rotating and everything. If you use lead weights, get a dynamic balance(weights on both sides). I had mine balanced 3 times and the weights were all over the place each time(one shop once and another twice). Just my experience with 33" TSLs.
    I swapped to 35" bfgs and didn't even balance the rear and bubble balanced the front and they were smoother than the TSLs.
  15. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Lead weights are great until you rip them off four wheeling. I will run the balancing media on my next set of tires.
    Harley
  16. ProJunkRacing
    Jun 20, 2005
    1,229
    FrankFort IL
    it might work , and crazy vibes probably
  17. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    If your out playing in rock hard enough to knock off hammer-on weights, don't you think your chewing up the tires and rims enough that they should be re-balanced anywhy?
    The reason I dont like the tape weights are I'm rumming 15" rims.... and if your playing in rocks don't the get in there at times and chew them up too?
  18. 78Suburban
    Jul 4, 2005
    2,609
    Georgia
    Those are the same tires I will be getting. So other than the DD issues (Mine is trail only) did you have any other complaints? Did they perform well off road? Did they clean well?
    thanks,
    James
  19. Inu-Hanyou1776
    Inu-Hanyou1776 1/2 ton status
    Oct 1, 2005
    1,345
    Murphy, NC
    Balancing tires with golf balls? What are you guys talking about? :doah: I've never heard that term before!
