ball joint 60..any good? no....((is this a 60??))
Discussion in 'The Garage' started by uglychevyZZ4, Apr 14, 2006.
  1. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    just curious, i know where one has been sitting and can easily come home with me.
  2. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Ford or Dodge?? Don't think the Dodge ones are all that good, but the Fords are defintaly better. Downfall is the balljoints, not as strong as kingpins, and expensive to go crossover, havta buy a whole knuckle...If the price is right, get it.
  3. Masiony
    Masiony 1/2 ton status
    Sep 2, 2005
    729
    Springfield, OR
    ball joints will hold up if the rig is light and the tires are not too big. but under a fullsize i wouldnt want them.
  4. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    biggest downfall is spring spacing(ford ones). They use the much wider 36.5" spring pad spacing. Means they are no where near a direct bolt in to a K5 or like frame rig, and when running big tires and low lift, expect tire rubbing on springs.
  5. uglychevyZZ4
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    it is a chevy.. its from a K30 1 ton, but dosnt look like a 60, he thinks its a d44, i dont ?????
  6. sledheadak
    sledheadak 1/2 ton status GMOTM Winner
    Apr 29, 2005
    1,283
    anchorage,alaska
    its looks like a 10b 8 lug from the holes in the rotor to me.
  7. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    external hub 8 lug d44.
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    Second that.
  9. jk3078
    jk3078 1/2 ton status
    Nov 12, 2005
    374
    Moyie Springs Id.
    I also agree. Some where on the diff will be numbers cast into to diff, usualy on the webbing around the lower right hand side. It should have somthing like 44 6f for a dana44 and 60f for a 60. The first # is tha axle series and the letter "f" is for front.
  10. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    Being external hub like that it would be a D44HD, INLESS someone swapped the HD stuff onto a 10 bolt.
  11. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yeah thats a 10 bolt. If you did get a BJ 60 make sure its a 60 and not a 50.
