BALL JOINT ADJUSTMENT?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rh88k5, Sep 15, 2002.
  1. rh88k5
    rh88k5 Registered Member
    Sep 11, 2002
    94
    Burlington, N.J.
    88 1/2 ton- my passengerside lower balljoint has some slop in it, my manual says I could adjust some of it by removing the upper balljoint nut and turning adjusting sleeve. Will this work? I already bought the new joints, but I am feeling a bit lazy. Has anyone tried this? Please let me know your results, thanks.
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    You can assume that since the lower joint already has some "slop" in it that any compensation you do (I personally have never heard of an adjustment, per se) is only a temporary fix, as the joint is probably on its way out. My advice would be to replace them all.../forums/images/icons/smile.gif
  3. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    yep time to redo em.
    not a bad job to do even for the weekend mech.
    Might as well do it all while yer at it, u-joints and such, it is all apart any way.
