Ball joint grease zerks
Discussion in 'The Garage' started by MTBLAZER89, May 21, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Just put my new ball joints in my knuckle the other night (other one is getting machined /forums/images/graemlins/waytogo.gif) and I put the supplied zerk in on the bottom and was thinking there will be a clearance problem with the axle joint. My current balljoints have nothing there, and the axle joint looks pretty close. Anybody run zerks in their upper balljoints, or do I need to put in those little block off nut thingy's instead /forums/images/graemlins/thinking.gif /forums/images/graemlins/peace.gif
  2. ilikemud
    ilikemud 1/2 ton status
    May 22, 2003
    111
    The Farmhouse, NJ
    put in the fittings grease em up real good, then put the nut thing in and dont lose the zerk!
  3. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What he said. /forums/images/graemlins/waytogo.gif
  4. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    yep, plug thingy.
  5. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Do those flat zerks for needle greasers on U joints work , or are they a different size? /forums/images/graemlins/thinking.gif
  6. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK where can I get some of those nut plug thingy's?
    /forums/images/graemlins/histerical.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/peace.gif
  7. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    On my upper ball joint, my zerk isn't coming straight out the bottom of the ball joint, it come out the side of the ball joint next to the bottom lip.
  8. scoutillac
    scoutillac 1/2 ton status
    Feb 24, 2004
    423
    Spokane, Wa.
    [/ QUOTE ] What kind are you buying. I would love to not have to take my hub assembly apart and pull the axle out to grease my uppers.
  9. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    MOOG's /forums/images/graemlins/thumb.gif
  10. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    My moogs were the same way, off set zerks (reason I chose them over spicer). I guess you could VERY carefully drill out the side/shoulder of the upper balljoint and put a zerk in there for regular lubing, and just plug the centered hole. I would be a little worried about metal flakes when drilling though.
  11. heavy4x4
    Aug 28, 2002
    3,270
    I've got Moogs with the angled zerk and it still didn't clear the axleshaft. /forums/images/graemlins/crazy.gif /forums/images/graemlins/dunno.gif
  12. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Here are mine, MOOG's with a straight zerk out the side shoulder.
  13. heavy4x4
    Aug 28, 2002
    3,270
    Correction: I have no idea what I'm talking about. /forums/images/graemlins/histerical.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/ignore.gif
    Sorry, I mis-read your post. /forums/images/graemlins/smirk.gif Mine don't look like that...they have the hole in the bottom of the balljoint, but the grease zerk has a 45 degree bend in it, and like I said earlier, it doesn't clear the axleshaft.
  14. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    The only thing I can think of is that might be a difference between a D44 and a 10bolt /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    But yeah, like others have said, just use a zerk to grease it, then pull the zerk and cap the hole and save the zerk. Another idea is to lift the joint boot and use a needle tip on the end of your grease gun and fill up the cup /forums/images/graemlins/thumb.gif
