ball joint help... (ALL DONE)
Discussion in 'The Garage' started by colbystephens, Mar 1, 2007.
  1. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    hey guys. sorry, no real time to do much searching. got a dana44 and i killed a balljoint today while driving. that was one of those pucker-your-ass and tell your wife it's all ok kind of moments. :) anyway, i'm getting a ball joint press to do the job, so it shouldn't be too hard, but i'm hoping to get some advice from y'all - make this easier on me. i've never taken apart my front hub - does it use the same socket as my 14bff? these are a matching set of axles, if that makes a difference. thanks for any input before i get too dirty to reply. :)
  2. BigEasy
    BigEasy 1/2 ton status
    Dec 18, 2006
    418
    U-jeen, Oragun
    It uses a different socket. Save yourself time & headache and have the local parts store press in the new ball joints. Even with the kit it's a real b!tch. You'll also need to get the spanner wrench to set the preload on the tapered sleeve for the top ball joint (the only place I could find these was Napa. Autozone quit carrying them and Kragen's had no idea what I was talking about).
    Spindle nut socket:
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=SER&PartNumber=2770&Description=Spindle+Lock+Nut+Socket
    Ball joint spanner wrench:
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BK&PartNumber=7002467&Description=Ball+Joint+Spanner+Wrench
    If you don't have a torque wrench, you'll need one of those too. It's a good idea to have all 3 of these items and a spare set of front shafts on the trail. Consider them an investment. Here's an excellent thread on how to change the ball joints:
    http://coloradok5.com/forums/showthread.php?t=183180&highlight=ball+joint
  3. 73k5blazer
    Dec 28, 2001
    4,987
    38
    The Rustbelt
    I dunno, I didn't think it was too hard. With the press, and spanner wrench, it's no so bad. The press is great. Works well on U-joints and other jobs requiring a giant c-clamp. I've found many innovative uses for it. Well worth the dough and a fine addition to any mechanics tool box.
    The front socket is different than the 14bff, nothing like adding to your toolset though!
  4. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    I tried using the kit on my ball joints with no luck. Ended up having the old ones pressed out and the new ones pressed in for $20. Maybe some are easier than others but mine were a real PITA. :dunno:
  5. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,125
    53
    Powell, Wy
    buy the tool and learn to do it yourself. You will be futher ahead in knowing how and have the tools to do it next time.
  6. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    I think you should fully expect that the truck will be down a full weekend, if not longer to do this (assuming you are doing both sides)
    to do my passenger side (learning) took me 2 days, driver side was 1 day mostly due to the giant steering block making things a PITA. Now I bet I could do both in 1 day.
    You also need a big breaker bar and maybe a cheater pipe for said breaker bar for the press... and a big vise or a helper to hold the knuckle while you crank the press
  7. BigEasy
    Dec 18, 2006
    418
    U-jeen, Oragun
    Sounds like my $20 was well spent. This was also my first time doing them and I did both sides, plus new bearings, seals, rotors, calipers, and locking hubs at a leisurely pace in one day. But I also had time to work on everything else while the new ball joints were being installed instead of continuing to fight the old ones.
  8. chevy wrangler
    chevy wrangler 1/2 ton status
    Jun 15, 2006
    3,035
    el paso, texas
  9. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    thanks guys! looks like i'm starting in tomorrow morning on the project - not exactly as planned. really appreciate it.
  10. jms
    jms 1/2 ton status Author
    Jan 24, 2001
    1,683
    Keep in mind, none of that "brute force" stuff - you know what happened with the driveshaft. This time it's gonna be your steering...
    I'd start spraying everything in PB blaster tonite.
  11. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    good tip! :)
  12. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    the old ball joints can be taken out with a hammer. no need to fumble with the press. take the knuckle off the axle. remove the snap ring on the lower balljoint. beat it out. use a brass drift and beat out the top balljoint.
    when you install them you need to do the lower balljoint first.
  13. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    what's a brass drift?
  14. bp71k5
    bp71k5 3/4 ton status Premium Member
    Mar 31, 2006
    6,235
    284
    San Jose, California
    A big piece of brass to hit with the hammer instead of wacking the joint directly. A piece of hardwood works ok too sometimes.
    But since you need the press to put them back in, you might as well use it to take them out too. :)
  15. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    ok, picked up all my parts/supplies tonite. the ball joints are sealed - what's up with that? there's no grease fitting, no place for a grease fitting. these are MOOG joints. that strikes me funny. i guess it's less maintenance tho. any thoughts?
  16. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    The sealed ones will go bad faster the the greasable ones.
    I say get the greasable ones
  17. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    You need to check your balljoints more often so this doesnt happen again....
  18. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    My MOOGs had the grease zerks:confused:
  19. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    this is a good point. up until thursday tho, i didn't know how to do it. i'm still not sure that i would know how to check for minimal play in the joint tho.
    after the joint died, i jacked that side of my truck up on the side of the road, lifted up on the wheel and felt TONs of play. looked at the ball joints while i was doing this and sure enough...
    now, how would you go about checking them if they are only starting to wear? i mean, how would you notice? seems that if you can feel any play, there's an issue - so how do you know before that point?
  20. gmc4cw
    Jul 19, 2006
    3,907
    west chester, Pa
    if you jack up the truck and pull on the top or bottom of the tire and there is movement it's time for new balljoints. pull on the sides and it moves time for new tierod ends.
    without movement they are good. simple and straightforward.
    unless your bearings are loose or worn. When I bought my blazer it pulled left when I was braking and one tire was worn on the inside edge. turned out the spindle nuts were loose on one side. balljoints were good and the tierod ends. but when I jacked it up there was movement both ways. you ahev to look at them as you pull on the tire.
