Ball joint install procedure?
Discussion in 'The Garage' started by toy4x4runner, Mar 6, 2006.
  1. toy4x4runner
    toy4x4runner 1/2 ton status
    Nov 3, 2004
    122
    Tampa, FL
    What's the "right" way to install ball joints on the D44? the instructions that came with my Moog ball joints say:
    -torque lower bj to 70 ft/lb
    -torque top adjuster to 70 ft/lb
    -torque upper ball joint castle nut to 100 ft/lb & install pin.
    Is that the best way to do it? I don't wanna have another ball joint mis-hap again.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I did mine just the same except my adjuster is at 50 ft/lb
  3. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    parts mike has a "how to" install D44 knuckles and he says to do the same thing pretty much except for final torque.... the lower to 140#. that's double what Moog specifies.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    yeah that WAY to much for the lower
    70 and 100 are correct
  5. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    Ok, so 70# for the lower. 50-70# for the adjuster. And 100# for the top.
    The Moog Ball joints seem to be very high quality and nice. they come with EXCELLENT DIRECTIONS, Grease fittings/plugs... everything. Much better than spicer just giving you the part in a empty box. That instruction sheet is where its at. Thanks for the input.
  6. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
  7. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Im installing ball joints soon too. Any idea where I can get the adjuster tool?
  8. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    moog is one of the best you can get these days.
  9. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    you can get the adjusting tool at Advance Auto I think in the tool aiel by the 4WD spindle nut socket. if not, Parts Mike has them. $10 is the going rate.
  10. sweetk30
    Nov 1, 2004
    25,548
    543
    are you talking the hub nut tool? i think he wants the ball joint upper pre load adjuster tool socket. much smaller size than the hub nut tool.
  11. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Yeah, the preload thingy
  12. toy4x4runner
    Nov 3, 2004
    122
    Tampa, FL
    yeah, the upper ball joint adjuster tool. I'm pretty sure they sell it at advance auto by the Hub tool.
