ball joint question / bent front diff???
Discussion in 'The Garage' started by bajaviking, Apr 3, 2007.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I recently had my balljoints replaced and right after picking up the truck I went wheeling. After coming home I noticed that both wheels are like this \ / and now I am not sure if the balljoints were installed wrong or if my front diff is bent.
    Can balljoints be installed wrong causing this \ / or is there only 1 position they can go in?
    I suspect the balljoints because the front diff tubes does not look bent and I was wheeling the whole day without feling any binding which I guess would be the case if the tubes were really bent:confused:
  2. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,992
    130
    Balljoints could be a problem, but if the wheel bearings were reinstalled incorrectly that could cause it too.
  3. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    That's how mine looked after I installed new ball joints.
  4. sweetk30
    Nov 1, 2004
    25,539
    538
    horseheads , ny 14845
    i bet loose wheel bearings of cheep b/j's and thay are junk now.
    chain store brand b/j's are junk now adays. get some moog or spicer b/j's when you do change them.
    if thay didnt install the nuts for the wheel bearings correctly thay might have backed off on ya. worst case i had one do this and it took out the spindle and locking hub before i got to it. :doah:
